Aktuellt datum och tid: tor sep 20, 2018 9:33
Ny tråd Svara på tråd  [ 604 inlägg ]  Gå till sida Föregående  1 ... 27, 28, 29, 30, 31
InläggPostat: mån okt 24, 2016 15:04
Hello and sorry for posting in English :)
I've been working in the past time to implement some functions for my05 XC90.
1. DIM messages, but no PHM module, tried to simulate a PHM module by changing the car config message described here: (unfortunately with no success)
viewtopic.php?f=9&t=23011&hilit=sweep&start=20
#And the second-last byte to be changed to "02" to fool DIM to have a PHM present.
send(can_id = 0x01017FFC, [0x15, 0x18, 0x03, 0x01, 0x02, 0x02, 0x02, 0x01], wait = 40)
#send(can_id = 0x01017FFC,[0x15, 0x18, 0x03, 0x01, 0x02, 0x02, 0x01, 0x01], wait = 10)#original message
###SVXC
###PHM####
send(can_id = 0x00800021, [0xE1, 0x1F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00], wait = 10)
send(can_id = 0x00800021, [0xA7, 0x00, 0x50, 0x49, 0x4E, 0x2D, 0x63, 0x6F], wait = 10)
send(can_id = 0x00800021, [0x21, 0x64, 0x65, 0x3A, 0x20, 0x20, 0x20, 0x20], wait = 10)
send(can_id = 0x00800021, [0x22, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20], wait = 10)
send(can_id = 0x00800021, [0x23, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20, 0x20], wait = 10)
send(can_id = 0x00800021, [0x65, 0x20, 0x20, 0x20, 0x20, 0x20, 0x00, 0x00], wait = 10)
2. Sweep the speed and rpm gauge
send(can_id = 0x000FFFFE, [0xCB, 0x51, 0xB2, 0x02, 0x00, 0x00, 0x00, 0x00], wait = 10)#test all instruments
send(can_id = 0x000FFFFE, [0xCE, 0x51, 0xB0, 0x09, 0x01, 0xFF, 0x04, 0x00], wait = 10)#ABS lamp ON
send(can_id = 0x000FFFFE, [0xCE, 0x51, 0xB0, 0x09, 0x01, 0xFF, 0x08, 0x00], wait = 10)#SPIN lamp ON
Any idea how to control only the gauge's? vida has no independent test for the gauges.
http://www.auxadapter.se/
viewtopic.php?f=40&t=25573&hilit=cem+dim
Best regards,
Adrian
InläggPostat: tis dec 20, 2016 19:08
Sorry for posting in English. I'm jumping back into the CAN world to build some features into an Arduino and one of the things I should have started last time was a spreadsheet of all the IDs and data. Has anyone done this? I cross posted this on motor-talk forums, too.
InläggPostat: tis dec 20, 2016 21:08
Does anyone have the PHM control/data ID for a MY 2006?
InläggPostat: lör nov 04, 2017 13:26
Tråkigt att tråden dog ut, skriver här ändå i hopp att någon erfaren skulle se detta, då det verkar vara enda stället det snackats så ingående om detta....
Jag tycker detta verkar som ett riktigt roligt projekt att fixa fjärrstart till dieselvärmaren på gammel-volvon (v70 2003) med arduino och sparkfun can-bus shield samt gsm shield.
Och ja, man kan köpa grejer från volvo men det är inte intressant, det är ju att fixa det själv som är kul :)
1. Är det någon som lyckats starta värmaren via can-bus? Jag har tidur i DIM samt direktstart. Man borde kunna sniffa upp koden som skickas när man aktiverar direktstart och använda den?
2. Var kopplar ni in er på can bus-slingan? Sparkfun säljer ju en färdig ODB2-kabel, går denna att använda?
3. Var kan jag få tag på exempelprojekt på andra grejer som ni gjort till era volvos? Bara för att se hur ni bygger upp koden.
Användare som besöker denna kategori: Inga registrerade användare och 2 gäster
