Aktuellt datum och tid: mån okt 15, 2018 9:04
Ny tråd Svara på tråd  [ 604 inlägg ]  Gå till sida Föregående  1 ... 26, 27, 28, 29, 30, 31  Nästa
InläggPostat: tis dec 02, 2014 16:20
Yes :) Det var ju det jag sa ovan.
Citat:
...via diagnoskommandon,...
InläggPostat: sön jan 04, 2015 18:17
Hello!
Few days ago received my ElecFreaks Can SHield
http://www.dx.com/p/elecfreaks-can-bus- ... ino-347142
Connected both wires from AEM cable to my can shield. White wire to CANH terminal and green wire to CANL terminal. Tried examples from arduino can shield library. But all I can get is CAN BUS Shield init ok! message in Serial port monitor and SRS-Airbag error in DIM and --:-- in place where clock should be. And when i start engine, tacho is not showing anything.
When I disconect can shield, everything works again.
What im doing wrong?
InläggPostat: sön jan 04, 2015 18:40
How about bus speed and termination resitor?
InläggPostat: sön jan 04, 2015 18:51
Tried different bus speed.
What about that resistor. I need to remove it?
InläggPostat: sön jan 04, 2015 19:09
You shouldn't add a resistor to an existing CANbus! It is already terminated correctly, so if your device has a resistor built-in you should remove it.
InläggPostat: sön jan 04, 2015 19:24
Removed resistor. The same. Once I connect arduino to Volvo, clock is gone and airbag error message appears.
Now I got new "error" instrument panel illumination is missing when can shield is connected.
InläggPostat: sön jan 04, 2015 20:49
Set shield in "monitor mode" and try.
InläggPostat: mån jan 05, 2015 1:13
That is typical for garbage on the bus or bus contention. It often happens if the bit rate is wrong.
InläggPostat: fre jan 09, 2015 22:00
Is it possible to send any information to my DIM LCD if i don't have phone module?
InläggPostat: sön jan 11, 2015 4:51
I väntan på prylar till mitt projekt i en annan tråd har jag bökat runt i VIDA och försökt räkna ut hur man skickar block med data. Jag har inte hittat någon beskrivning någon annanstans och det kanske finns fler som undrar...
Nedan är en kodsnutt för att skicka block med data som jag fiskat fram. Första byten är ju som bekant formatbyten i D2 protokollet. För meddelanden som är endast en frame så är formatbyten 0xC8 + len & 0x07 (200+ len & 7) vilket är bekant för de flesta som analyserat can bus datat, annars 0x8F. För mellanframes är formatbyten 0x08 + frameno & 0x07. För sista framen är formatbyten 0x48 + nbytes & 0x07, dvs antal kvarvarande bytes att skicka.
Ex: skicka block till ECU adress 50
0x000FFFFE 8F 50 DD DD DD DD DD DD
0x000FFFFE 09 DD DD DD DD DD DD DD
0x000FFFFE 0A DD DD DD DD DD DD DD
0x000FFFFE 49 DD 00 00 00 00 00 00
Kod:
public byte[] Send(NodeAddress nodeAddress, byte[] data, uint msReadTimeout, ushort numOfRetries)
   if (data.Length < 2)
      return new byte[0];
   this._interpreter = new D2ResponseInterpreter(data);
   this._nextReply = null;
   this._currentBufferMessage = 0;
   this._message = null;
   this._canChannel.ReadTimeout = msReadTimeout;
   J2534Logger.LogData(data, true);
   byte[] array = new byte[]
      0,
      15,
      255,
      254
   byte[] array2 = new byte[8];
   byte[] array3 = array2;
   int num = data.Length / 7 + ((data.Length % 7 == 0) ? 0 : 1);
   for (int i = 0; i < num; i++)
      int num2 = 7;
      if (num == 1)
         num2 = data.Length;
      else
         if (i == num - 1)
            num2 = data.Length - i * 7;
      byte b;
      if (num == 1)
         b = 200;
         b = (byte)((int)b | (num2 & 7));
      else
         if (i == 0)
            b = 143;
         else
            if (i == num - 1)
               b = 72;
            else
               b = 8;
               b = (byte)((int)b | (i & 7));
      PASSTHRU_MSG pASSTHRU_MSG = new PASSTHRU_MSG();
      pASSTHRU_MSG.ProtocolID = this._canChannel.ProtocolType;
      pASSTHRU_MSG.RxStatus = 0u;
      pASSTHRU_MSG.TxFlags = 256u;
      pASSTHRU_MSG.Timestamp = 0u;
      pASSTHRU_MSG.ExtraDataIndex = 0u;
      array.CopyTo(pASSTHRU_MSG.Data, 0);
      array3.CopyTo(pASSTHRU_MSG.Data, array.Length);
      pASSTHRU_MSG.Data[array.Length] = b;
      Array.Copy(data, i * 7, pASSTHRU_MSG.Data, array.Length + 1, num2);
      pASSTHRU_MSG.DataSize = 12u;
      J2534Message j2534Message = new J2534Message(this._data, 1, J2534Settings.DiagnosticReadBufferSize());
      j2534Message[0] = pASSTHRU_MSG;
      if (!this.CanWrite(j2534Message))
         return null;
      if (i < num - 1)
         Thread.Sleep((int)this._t1Min);
   bool flag = false;
   byte[] result = this.ReadFilteredReply(ref flag);
   if (flag)
      flag = false;
      this._nextReply = this.ReadFilteredReply(ref flag);
      this._nextReplyIsLastFrame = !flag;
   else
      this._nextReplyIsLastFrame = true;
   return result;
InläggPostat: lör jan 17, 2015 19:02
Någon som har johnnys program easy logger 1.0 och det som behövs för att få igång detta projekt?
InläggPostat: tor jan 22, 2015 8:37
Morning Everyone,
Can someone tell me is it possible to retrieve Can Id for Reverse Gear on Manual gearbox ?
InläggPostat: tor jan 29, 2015 10:20
Hello,
Could you help to calculate Engine coolant temperature on my V70 2006?
Send: 0x00FFFFE - CD 7A A6 10 1A 01 00 00
Response: 0x1200021 - CD 7A E6 10 1A 7A 00 00
formula is 0x10 - 40 => 16-40 = -24°C
What is wrong here ?
InläggPostat: mån feb 09, 2015 13:20
japonne skrev:
Hello,
formula is 0x7A *160/255-40 => 122*160/255-40 = 31.55°C
InläggPostat: fre apr 17, 2015 23:57
Snabb fråga, jag har köpt en begagnad CFE och adapterkablaget är "delat". Är det någon som vet om CFE:ns gula ska till grön eller vit och förstås då om den gråa ska till grön eller vit. :wink:
(Jag har även mailat Volvotech, men dom lär väl knappast svara på helgen) :)
Tack på förhand!
* Klicka för mer bilder/info om min Volvo V70 D3 -11 *
InläggPostat: sön apr 19, 2015 13:01
Om det bara är CAN H / L du leker med så kan du ju faktiskt pröva, om du tar så fel fungerar det helt enkelt inte :) Kan givetvis ge någon felkod / störning men det är jag säker på att du klarar att nolla själv om så händer.
InläggPostat: sön apr 19, 2015 14:28
Intressant tråd :) En fråga till alla duktiga kunniga :)
Har en S80 2007 och ett DIM mätarhus från nya Modellen (TFT)
Hur får man det att funka?
Har förstått det handlar om CAN signaler m.m men kan inte ett jota i det :/
Nån som känner sig sugen att dyka i ämnet?
InläggPostat: sön apr 19, 2015 14:56
Tack! Ingen minns en fegis så jag provade redan igår, och precis som du skriver så hände ingenting när jag kopplade "fel". :D
InläggPostat: sön apr 19, 2015 20:22
:thumright:
InläggPostat: sön apr 19, 2015 20:29
Ja visst vore det häftigt! Jag har redan tänkt den tanken men tyvärr så kräver det en liten detalj som gör det närmast omöjligt!
Problemet: Finns ingen mjukvara för TFT-huset som stöder din bils CAN kommunikation.
Lösning: Skriv egen mjukvara från scratch som driver TFT-display, visare, ljud och övrig info baserat på din bils CAN protokoll.
Genomförande: En praktisk mardröm att utföra programmeringsjobbet utan redig dokumentation på hela TFT instrumenthuset inklusive vilka externa parametrar som ska behandlas och i många fall besvaras på CAN-bussen.
Resultat: Det skulle helt enkelt kräva så mycket reverse-engineering jobb att du direkt borde anställas på Volvo efter detta för du vet troligen mer än dom som skrev den ursprunglig C-koden.
Jag utgick också ifrån att du inte har en S80N där det faktiskt kunde gå att montera ett sådant TFT-DIM 8)
fast detta är ju bara min åsikt...
Användare som besöker denna kategori: Inga registrerade användare och 2 gäster
